What inputs does a particleInstancerNode need?
haggi_master
haggi_master
I wrote a shape node which reads particle data via the Disney open source Partio library what works quite fine. Now I want be able to output the correct data in a way which allows me to connect the ouput to an particle instancer node. As much as I know this is a quite complex nested compound attribute. Does anyone know the structure of such an attribute?
haggi_master
What I have tried so far is defining an output as:
	outInstanceData = tAttr.create( "outInstanceData", "outInstanceData", MFnData::kDynArrayAttrs);
	tAttr.setStorable(false);
	addAttribute( outInstanceData );
And in the compute method I created some test Data:
		MFnArrayAttrsData	instancePointDataFn;
		MObject				instancePointDataObj = instancePointDataFn.create();
		MVectorArray		outPosArray = instancePointDataFn.vectorArray("position");
		MIntArray			outIdArray = instancePointDataFn.intArray("id");
		MDoubleArray		outAgeArray = instancePointDataFn.doubleArray("age");
		MDataHandle instanceDataHandle = datablock.outputValue(outInstanceData);
		instanceDataHandle.setMObject(instancePointDataObj);
		outPosArray.append(MVector(0,0,0));
		outPosArray.append(MVector(1,0,0));
		outPosArray.append(MVector(2,0,0));
		outPosArray.append(MVector(3,0,0));
		outIdArray.append(0);
		outIdArray.append(1);
		outIdArray.append(2);
		outIdArray.append(3);
		outAgeArray.append(0.0);
		outAgeArray.append(0.1);
		outAgeArray.append(0.2);
		outAgeArray.append(0.3);
		datablock.setClean(plug);
But this was not successful, I do not see any instances. So what's wrong here?
haggi_master
If I set the line
at the end before the setClean(), the whole thing works fine.
