UV Tool Seems to be Broken
For some reason my uv tool seems to be broken and not working as it should be.
I noticed this the other day I go to use the unfold on one uv shell but then it unfold all the shells in the uv editor. If I use the straighten shell on one line it seems to break the shell. I've never had this issue before or a problem with uving.
I have tried resetting the settings. (I haven't reset the preference yet though, as I am a little unsure on how to do this)
Many thanks!
mcw0
To reset your preferences, just rename your "prefs" folder to something else.  When Maya launches, if there's no prefs folder, it will create a default one.
