Undo PlaybackOptions command
neilrubieHFV88
neilrubieHFV88
I can't seem to undo the playbackOptions command used to adjust the playback range. For example:
cmds.playbackOptions(animationStartTime=10, minTime=10)
According to the doc this is an undoable command, but it does not seem to be entering into the undo queue. Curiously, if I drag the slider with the mouse, that DOES undo... which isn't all that helpful for me.
Am I missing something or is this a bug?
(I am using Maya 2023.3 on linux)
brentmc
Working here on Windows. You haven't accidentally disabled undo or anything have you?
Brent McPherson
Principle Engineer
neilrubieHFV88
Undo is indeed enabled. In fact it just goes and undos whatever command came before the playbackoptions command.
