Trouble Rendering from Command Line
 Im using Windows 10 and Maya 2016 ( student edition).
 Rendering using mental ray from command line.
 Getting this error:
fatal 211109: runtime exception 0xc0000005: access violation
 ???? Command.pngHelp !!
See attachment
jeffrey.sin
Hi @Anonymous,
Have you already tried downloading and installing all the updates or service packs available for Maya 2016? You can find them here.
Additionally, check and try out the suggested solution provided here for a similar incident that occurred before: Mental Ray Fatal Error
I hope this information helps, let us know how it goes.
Jeffrey Sin
Autodesk Customer Support
Jeffrey,
thanks for the reply !
I'm getting an error message when I try
to download Maya 2016 service pack 2 for windows.
See image attached.
kollig
If you add "-v 5" or even "-v 6" to your command line you will get more output from mental ray. May be this helps to figure out where it hangs.
