I want to run a certain callback after anytime a new file gets referenced. I want to do this in python.
According to the docs this should be possible: https://help.autodesk.com/view/MAYAUL/2018/ENU/?guid=__py_ref_class_open_maya_1_1_m_scene_message_ht...
But when I register callbacks for kAfterLoadReference or kAfterLoadReferenceAndRecordEdits, the function never gets triggered. I connected a debugger and set a breakpoint and the callback function never even gets entered.
kAfterImport works as expected. Am I missing something obvious here, or is something actually broken?
Example code below, it creates a simple scene with a cube in it, registers multiple test callbacks, then references in the cube, then imports the cube.
I'm in maya 2018.2
#create a new file called cube.ma, has a cube in it
TEST_SCENE_NAME = 'cube.ma'
cmds.file(new=1, f=1)
cmds.polyCube()
cmds.file(rn=TEST_SCENE_NAME)
cmds.file(s=1, f=1, type='mayaAscii')
#register callbacks
import maya.api.OpenMaya as om2
def onReferenceLoad(clientData=None):
print '#'*20
print 'This is a callback'
print '#'*20
id1 = om2.MSceneMessage.addReferenceCallback(om2.MSceneMessage.kAfterLoadReferenceAndRecordEdits, onReferenceLoad)
id2 = om2.MSceneMessage.addCallback(om2.MSceneMessage.kAfterLoadReferenceAndRecordEdits, onReferenceLoad)
id3 = om2.MSceneMessage.addReferenceCallback(om2.MSceneMessage.kAfterLoadReference, onReferenceLoad)
id4 = om2.MSceneMessage.addCallback(om2.MSceneMessage.kAfterLoadReference, onReferenceLoad)
id5 = om2.MSceneMessage.addCallback(om2.MSceneMessage.kAfterImportReference, onReferenceLoad)
id6 = om2.MSceneMessage.addCallback(om2.MSceneMessage.kAfterImport, onReferenceLoad)
#would expect this to trigger the callback method 5 times, doesn't trigger at all
print 'Referencing the test file'
cmds.file(TEST_SCENE_NAME, r=1, type='mayaAscii')
#correctly triggers the one callback registered
print 'Importing the test file'
cmds.file(TEST_SCENE_NAME, i=1)
#unregister callbacks
om2.MSceneMessage.removeCallbacks([id1,id2,id3,id4,id5,id6])
