Announcements
tkinter import won't work
I'm trying to write some python script and implement some GUI. I can't get the Tkinter to import by simply typing :
import Tkinter as tk
I get this error:
# Error: ImportError: dlopen(/Applications/Autodesk/maya2011/Maya.app/Contents/Frameworks/Python.framework/Versions/Current/lib/python2.6/lib-dynload/_tkinter.so, 2): no suitable image found. Did find: /Applications/Autodesk/maya2011/Maya.app/Contents/Frameworks/Python.framework/Versions/Current/lib/python2.6/lib-dynload/_tkinter.so: mach-o, but wrong architecture
Hope someone can help,
Cheers.
That's because tkinter is only 32 bit, but you're running maya 64 bit. You must either get a 64 build of tkinter, or run Maya 32 bit.
