Tips for debugging crash on GUI startup
barnabas79
barnabas79
So I'm currently investigating a crash which always happens immediately on GUI startup.  It causes a script editor window to briefly open, with what looks like might be relevant information (?), but the window then closes before I can read it.
I was wondering if anyone had any tips for tacking this problem - either:
- An easy way to turn on maya logging (preferrably via an environment var - the MAYA_APP_DIR is actually in a temp dir in this case, because the crash happens during a unittest)
- A way to make the script editor window stay open
...or anything else that you think might help.  Thanks!
stuzzz
You might set the environment variable to you Maya.env
MAYA_DEBUG_ENABLE_CRASH_REPORTING = 1
You will usually found the
specify a log file in a path  like: C:\Users\<YOUR USERNAME>\AppData\Local\Temp\MayaCrashLog<token>.log
stuzzz
I was editing my text when when the post got validated. It's barely english, sorry for that!
