Announcements
settAttr outside the undo queue on TimeChanged
AronDurkin
AronDurkin
Hey Folks
I've got a scriptNode with "setAttr" on a string attribute in on timeChanged, this is filling up the undoQueue and annoying people. Can I efficiently get it out of the undo stack or set a stringg attr some other way? Genereally I'd like scriptNodes and scriptJobs to not be in the undo stack.
stuzzz
I believe that the OpenMaya commands have no history record.
The solution would be to use the MPlug class
Here's a C++ snippet, you can switch to python if needed.
MFnDependencyNode plugFn(nodeObj);
MPlug plug = plugFn.findPlug(plugname, false);
plug.setXXX(value);
AronDurkin
thanks, is this preferable / more performant (if called from python API) than putting the setAttr into "eval -ue 0" which I recently tried?
stuzzz
It's a matter of a fraction of microseconds. It won't alter your performance at all.
