setSomeUVs not setting uvs?
smartincoreanimation
Message 1 of 1
Hi!
I've been working on a script to extrude the uvs of a selected edge in the direction of the normal of the edge in uv space.
I got it working with polyEditUV, but it is slow to run when theres many uvs to extrude, so I found the setSomeUVs method. Green works, Red doesn't (Screenshot is manufactured to show the problem, if there's any syntax errors thats not it)
I've read the docs about setSomeUVs. It says you need yo update uv assignment if you added new uv ids, but I don't do that, all vertices of this mesh have uv coords and so uv ids.
Is there a problem with my way of doing things? Do setSomeUVs work for you?
Tested on Maya 2024.2
Replies (0)
