Selecting Nodes with Python
danispag
danispag
Hi, I would like to select nodes with python. I managed to make a list and print the object that i want however when i'm running the select function nothing is selected.
Please refer to image attached below.
Your help is very much appreciated.
Thanks and regards
Daniel
lanh.hong
Hi Daniel,
When you use the select command, you can add each node to the active selection list by using the add flag. As you loop through all of the nodes, this will select all of it.
import maya.cmds as cmds
nodes = cmds.ls(type = ['transform']) nodesLen = len(nodes) for i in range(0, nodesLen): print(nodes[i]) cmds.select(nodes[i], add=True)
More details about the select command and its flags can be found here: http://help.autodesk.com/view/MAYAUL/2018/ENU/?guid=__CommandsPython_select_html .
Hope this helps!
Lanh
Lanh Hong
Developer Technical Services
Autodesk Developer Network
If the only thing that you want to do is selecting the nodes listed by the cmds.ls function, you don't need to loop over the list of nodes, the cmds.select() function accepts a list as parameter:
nodes = cmds.ls(typ=['blendColors', 'clamp'])
cmds.select(nodes)
danispag
Thanks a lot, the 'add' flag was the solution 🙂
