Announcements
Select object one by one and do some operation on it?
I'm not familiar with MEL but i'm sure this is pretty easy and can takes me way less time than doing by hand this.
In my case I would select one object and do a combine on it (polyUnite). Then selecting the next one and so on...
The problem is that when I use MEL it select all the objects. Can you help me making it easier ?
Thank you !
lee.dunham
you cant combine on just 1 object, so im abit confused.
can you provide an example?
as for looping and performing actions you typically use
string $mySel[] = `ls -sl` ;
for($sel in $mySel){
//do command on $sel
To be more precise my objects are transform objects that have multiples shapes. (It's a CAD files I'm using).
To clean the multiple shapes into 1 shape and 1 object I need to combine it.
But I wish to keep the transform separate to each other so I don't combine 2 objects, only the shapes.
It results an error :
polyUnite -ch 1 -mergeUVSets 1 $sel
// Error: }; //
// Error: Syntax error //
// Error: //
lee.dunham
this should work then.
// get shapes of object
string $children[] = `listRelatives -s -fullPath $sel` ;
// combine and store new objects
string $newObject[] = `polyUnite -ch 1 -mergeUVSets 1 $children` ;
// delete old transform node and rename new to old
delete $sel ;
rename $newObject $sel ;
Thank you for the tip !
It works wonderfully !
But the mesh generated miss something that I need to set a new shading group otherwise I only see the edges when I higlight it.
I seems like that it happen when I use the rename script. So I get rid over this part 🙂
Thank you so much 🙂
Can I ignore error message that make the script stops ? It happens because some of my objects don't have multiple shapes in it so it fails to combine and result as an error.
