Announcements
Select materials from objects hotkey from outside hypershader?
i_am_fail
i_am_fail
I'm just starting to get into maya programming, and something extremely useful I would like to do is:
I have already set up a hotkey, when the Hypershade window is active, pressing "M" will run the Edit -> Select Materials from Objects command.
I would like this hotkey to be activatable while in the model viewport though, it's annoying having to target my mouse over the hypershade window each time I make a new selection and want to see the material.
Is there a way to programmatically hook up firing the "Select Materials from Objects" command from a hotkey inside the viewport - not the hypershade window?
i_am_fail
figured it out, see screenshot
