ScriptJobs?
ScriptJobs?
ScriptJobs?
Guys I am stuck !
I have a massive problem trying to do camera script-job. I want to get a callback everytime I move the camera using the alt+right / left button aka rotating or zooming.
I simple cmds.scriptJob(attributeChange=) does not do the trick as the camera attributes does not change unless you release the mouse button.
The built in may lodsystem uses some form of callback from the camera so it must excist !!
Any one got any ideas ?
// Krister - Ava Studios
lee.dunham
Hi Krister,
I've always had some difficulty using the attribute change trigger in scriptJobs, with unexpected results.
Would it be possible to use an expression and conditions instead?
basically i need to trigger a function every time I move my camera or to be more specific every time the camera distance to a target changes.
further information: I am doing my own lod system based on screenspace size =P
lee.dunham
hmm you might be better off using a distanceBetween node instead of going by the attributes on a camera.
The script Job should be able to pick up the distanceBetween.distance attr and run from that?
I'm unable to test atm but give that ago.
sorry no go
made a destancebetween node, connected camera and a sphere as input and runs
mc.scriptJob(attributeChange= )
unfortunate this still does not trigger the callback until I have let go of the mouse button.
If I only had a way of getting regular callbacks =(
I am starting to think that an evil while loop that runs every x frame is the option,, but its going to add a constant lag to maya =(
