SCRIPT PYTHON ML LOOMIS TOOLS
luisandro.garza
luisandro.garza
I have installed many scripts in Maya, and all of them work fine. I am struggling like heck to add this one.
https://github.com/morganloomis/ml_tools
I've tried adding the shelf and individually adding scripts, nothing I get the same errors for all of them. I had it working for a session and then it just stopped, no idea what happened or what I did to get it to work. There has to be a utility installed first to get the rest to work which I installed according to the directions.
Can someone translate this to English because adding this to the file folders like all the others isn't working? I need some other than obvious answers, "did you upload to the correct file path?"
This is the error for the utility.py
This is the shelf there are several tools but none will work without the utility.py being installed.
Can someone translate this for me? What do I do with this information? I know how to get to the environment variable but when I set the path nothing happens.
s221310
Community Visitor
Community Visitor
I’m having similar difficulties installing ml_utilities and ml_worldBake. Have you had any success installing anything ml related since posting?
luisandro.garza
You need to add them individually to the “script” folder. For some reason
it wouldn’t read the script when I had them in the “MLoomis” folder
s221310
Community Visitor
Community Visitor
Yeah I've got them in there individually and its still not working for me.
