Announcements
Saving issues
Saving issues
24830481
Observer Observer
Saving issues
24830481
Observer
Observer
One of my files isn't able to save or export without crashing immediately before completing. After crashing it'll at least create a file of the saved copy, however if I try to open the saved copy it wont load any assets or any saved data.
The original file turned into a MBA23772 file type so it isn't recognised on this forum but I've tried attaching some of the copies that I could convert back into maya files by renaming them but when trying to submit, the following error code appears:
  • The attachment's suroomreal - copy.mb content type (application/octet-stream) does not match its file extension and has been removed.
What really confuses me is the fact the file has the same amount of KB as if it had all the assets in it yet doesn't load anything when opened.
damaggio
you need to zip first, also your file is in the wrong format .mb
