Rotation order constants
I noticed the the constants for the rotation order differs:
OpenMaya.MEulerRotation.kXYZ = 0
OpenMaya.MTransformationMatrix.kXYZ = 1
is there reason for this?
Br,
Johan
cheng_xi_li
Autodesk Support
Autodesk Support
They are C++ wrappers. For MEularRotation, kXYZ is the first enumerable, so the value is 0; MTransformationMatrix, the first enumerable is kInvalid and the one after is kXYZ, so it is 1.
Yours,
Li
Thanks for your reply.
It was a little bit of a gotcha to discover this the "hard" way, I was expecting the enums to be that same, seems more logical?
Couldnt kInvalid be -1 and keep the rest the same?
BR,
Johan
cheng_xi_li
Autodesk Support
Autodesk Support
I am not sure about it. Using kInvalid 0 has its own advantage in C++, 0 is false and there are other classes using 0 as invalid value also.
Yours,
Li
