RotateManipulator.setInitialRotation not working with rotateOrder
jmreinhart
Advisor Advisor
jmreinhart
I have a custom transform node that has an offset rotation attribute (similar to the joint orient attribute). I'm working on a custom rotationManipulator to work with it. I'm using the standard rotateManip but using callback methods to connect the plug and manipulator so that I can take into account the offset). This is working perfectly in XYZ rotation order, but when I switch to another one, the setInitialRotation method gives unexpected results.
It seems as though it expects the input rotation to be XYZ. If that's the case then I just need to convert my rotation from whatever order it has to XYZ but keep the same end orientation. How can I do that?
jmreinhart
MMatrix resultMatrix = (rotateQuat).asMatrix();
MTransformationMatrix mt(resultMatrix);
double resRot[3];
MTransformationMatrix::RotationOrder mtRotateOrder;
mtRotateOrder = MTransformationMatrix::kXYZ;
mt.getRotation(resRot, mtRotateOrder);
MGlobal::displayInfo(MString("initX:") + resRot[0]);
MGlobal::displayInfo(MString("initY:") + resRot[1]);
MGlobal::displayInfo(MString("initZ:") + resRot[2]);
mtRotateOrder = MTransformationMatrix::kYZX;
So I thought that this method would work but no matter what value I assign to "mtRotateOrder" it always gets an XYZ rotation.
jmreinhart
mtRotateOrder = MTransformationMatrix::kZYX;
mt.reorderRotation(mtRotateOrder);
I also tried this method but no matter what rotateOrder I chose to convert to it always worked when the object was in XYZ mode but not in any other mode.
jmreinhart
So it turns out that when you are in object mode rotation you should setInitialRotation using an EulerRotation with the same rotateOrder as your object. Seems obvious, I was getting weird results in my tests because I didn't realize the plugToManipCallback was being called.
