Render Setting - I want to know the mel command to switch to Render Elements tab.
tjdrbrla
tjdrbrla
I can do the command to turn on the render setting window by myself, but I can't find the command to switch to Render Elements Tab. Could you tell me through Mel command?
Kahylan
Hi!
Can I ask why exactly you need to open this rendersettings tab via a script? What is the endgoal?
Addressing the rendersettings window is quite challenging especially with external and older renderers like Vray. Maybe whatever you want to do can be done without using the UI?
tjdrbrla
Hi~
I created a command to add channels for Render Elements through the mel command, and when I used it, the Render Settings window turned on, but I wanted to switch to the Render Elements tab and check it.
It wasn't that important because it was just for checking. I thought it was simple because it's switching tabs to render setting. You don't have to tell me if it's hard. Thank you for telling me.
Kahylan
I did some tests and I found the command to do this:
setAttr  -type "string" "defaultRenderGlobals.currentRenderer" "vray";
unifiedRenderGlobalsWindow;
tabLayout -e -selectTab "vrayRenderElementsTab" "vrayTabLayout";
luckily vray tabs are named uniquely so there wasn't the usual problem with mayas automatic namegeneration in the unifiedRenderGlobals that can cause problems with some renderers.
I hope it helps!
tjdrbrla
Hello!
Thank you~! You did exactly what I wanted!
You're so cool.
Thanks to you, it's settled.
