Radiobuttons -en false and then set to true?
hi,
i am trying to set up a UI that has 2 sets of radioCollections. depending on the state of the first set, the second will become enabled or not.
cant get the second set to become enabled. here is the code:
window;
columnLayout;
// create the first radio collection
$radio1 = `radioCollection`;
// add some radio buttons to the collection
$off = `radioButton -label "Off" -onc "updateradio(0)"`;
$on = `radioButton -label "On" -onc "updateradio(1)"`;
separator -w 50 -style "single";
// create the second radio collection
$radio2 = `radioCollection`;
$X = `radioButton -label "X" -en false`;
$Y = `radioButton -label "Y" -en false`;
$Z = `radioButton -label "Z" -en false`;
// edit the radio collections to set the required radio button
radioCollection -edit -select $off $radio1;
proc updateradio(int $arg) {
if($arg){
radioButton -en true $X;
radioCollection -edit -select $X $radio2;
// now show the window
showWindow;
thanks
-a
lee.dunham
I had issues with your code, not passing the radioButton strings to the proc so i rewrote it how I would have.
Im assuming this is how you wanted it to work.
if(`window -ex rb_test_win`)
deleteUI rb_test_win ;
window rb_test_win ;
columnLayout ;
radioCollection rCollection01;
radioButton -label "On" -onc "updateradio 1";
radioButton -label "Off" -onc "updateradio 0" -sl;
radioCollection rCollection02;
radioButton -label "X" -ed 0 X_rButton;
radioButton -label "Y" -ed 0 Y_rButton;
radioButton -label "Z" -ed 0 Z_rButton;
setParent.. ;
showWindow rb_test_win ;
radioButton -e -en $arg -sl X_rButton;
radioButton -e -en $arg Y_rButton;
radioButton -e -en $arg Z_rButton;
