querying components blendshape weights
asavaris
asavaris
hi,
is there a way to query a per-vertex blendshape deformer weight value? The values you can set via sculpt and via component editor, but using MEL.
The percent command returns a // Error: No match to deformer name. //, like it doesn't see the blendShape node as one of the kind it can handle (it works for clusters, for example).
cheers,
Asavaris
example:
to get the target wight for vertex 54 on a blendShaope with only one target:
getAttr "blendShape1.it.itg.tw";
asavaris
example:
inputTarget.inputTargetGroup.targetWeights: thank you so much for the hint!
have a nice day,
asavaris
