query cachefile name
creativeplanet
creativeplanet
a simple question - i'm just starting.
I need to get the name of the cacheFile associated with the selected object to be able to modify its parameters. I have an object called let's say Object and its cachFile is called ObejctCache1. how to query that name ?
string $sel[] = `ls -sl`;
string $obj;
string $cache;
for ($obj in $sel)
$cache = ....($obj->cacheFile->filename)
setAttr ($cache +".oscillate") 1;
thanks!
rajasekaransurjen
Try this....
ls -type cacheFile;
This will list all cache nodes in the scene.
creativeplanet
Thanks for your help. Unfortunately it doesn't solve our problem. I need to get the name of the cacheFile for a given selected object. We have multiple objects in a scene and multiple cache files. As you see in the script I would like to get the name of the cache file associated with selected object.
Maciej
rajasekaransurjen
OK.....
Try this......
string $rsSl[] = `ls -sl`;
for($i=0;$i<size($rsSl);$i++)
    string $rsLstHst[] = `listHistory $rsSl[$i]`;
    select $rsLstHst;
    string $rsSlObjCache[] = `ls -type cacheFile`;
    print $rsSlObjCache;
creativeplanet
Thank you.
rajasekaransurjen
You are welcome.
