python to display xyz points
ssai99G56
Observer Observer
ssai99G56
Observer
Observer
I have some xyz points (3D points), and I want to plot them in the MAYA console using python. Does anyone has done it before?
chaneyx
I often use expressions with particles when I want to do a quick graph for of some math function.
You can create a fixed ( or variable ) number of particles. And then set expressions on the position of the particles.
OR if you are reading from a file , you can run a script in the script editor that reads your values and creates a  MEL command like this :
particle -p 0 0 0 -p 3 5 6 -p 5 6 7 -p 9 9 9;
ssai99G56
Observer
Observer
Thanks a lot. I am able solve it using python using your reference.
