Announcements
Python API findKeyframe command not working properly
firat.cicekFTQ7L
firat.cicekFTQ7L
Hi, I am facing an issue when using the findKeyframe command.
I was using this command while building a tool but it showed unexpected behaviour.
Here I'm using the script editor in Maya 2023.2 to find the previous keyframe before keyframe 5:
As you can see the value I'm getting is wrong. The value should be 4 because the previous keyframe is keyframe 4.
The same thing happens if I specify that I want to get the next keyframe after keyframe 5:
It is supposed to show the value 6 because that's the next keyframe after 5. But the result is still keyframe 5.
Does anyone have an idea what the problem is? Is this a bug?
jmreinhart
I just tested this myself in Maya 2023.2 and got the expected result.
cmds.spaceLocator()
cmds.currentTime(4)
cmds.setKeyframe()
cmds.currentTime(5)
cmds.setKeyframe()
print(cmds.findKeyframe(which="previous", time = (5,5)))
Could you run this script as a test? There may be something unusual about your scene that is causing an issue.
firat.cicekFTQ7L
Yes, this works for me. Thank you. I realized I had no keyframes in my scene.
