PySide window with designer ui doesn't generate closeEvent
I can't create a ui from a designer file and then have closeEvent  called when I close the ui.  I think I need to load the ui file differently, but I can't figure out how to do that in PySide.   I've tried many variations on this, and no matter what I do, the closeEvent doesn't seem to get sent when I close the window (clicking on the x) when using the ui file.  What am I missing?
Here's my ui file, (test.ui)
<?xml version="1.0" encoding="UTF-8"?>
<ui version="4.0">
 <class>Dialog</class>
 <widget class="QDialog" name="Dialog">
  <property name="geometry">
   <rect>
    <width>400</width>
    <height>300</height>
   </rect>
  </property>
 </widget>
</ui>
And here's my code:
class testClass(QtWidgets.QDialog):
    def __init__(self, useUiFile):
        super(TestClass, self).__init__()
        if useUiFile:
            self.ui = QtUiTools.QUiLoader().load("test.ui")
            self.ui.show()
        else:
            self.show()
    def closeEvent(self, event):
        print("closeEvent!!!!!")
If I don't use the UI file, my closeEvent gets called when I close the window:
ui = testClass(0) # calls closeEvent when closed
If I use the UI file, a closeEvent doesn't seem to be generated:
ui = testClass(1) # doesn't call closeEvent when closed
cheng_xi_li
Autodesk Support
Autodesk Support
Because you've created a widget with QUiLoader and its closeEvent wasn't overriden.
To make the closeEvent in your testclass work, you'll need to add that widget created from QUiLoader to testclass as a child.
e.g.
import PySide.QtGui as QtWidgets
import PySide.QtUiTools as QtUiTools
import PySide.QtCore as QtCore
    def __init__(self, useUiFile, parent=None):
        super(testClass, self).__init__(parent)
        if useUiFile:
            self.ui = QtUiTools.QUiLoader().load("e:/test.ui")
            mylayout = QtWidgets.QVBoxLayout()
            mylayout.addWidget(self.ui)
            self.setLayout(mylayout)
            #It will be empty because there weren't any widgets in the sample ui file.
            self.show()
        else:
            self.show()
ui = testClass(1)
Yours,
Li
Thanks, that worked perfectly.  And now I know...
