Announcements
PySide: maya.OpenMayaUI.MQtUtil.mainWindow() returning SwigPyObject
Hi, I'm using Maya 2014. Apparently you don't have to build anything to use PySide.
According to this:
http://docs.autodesk.com/MAYAUL/2014/ENU/Maya-API-Documentation/index.html?url=files/GUID-66ADA1FF-3...
You get the main window by using maya.OpenMayaUI.MQtUtil.mainWindow() then pass that result to shiboken.wrapInstance. mainWindow() returns a SwigPyObject that always causes an error when using shiboken.wrapInstance that says: Error: TypeError: You need a shiboken-based type.
cyrille
Hi
I just run the following script with no issue
import sys
import maya.OpenMayaUI as mui
from PySide import QtCore, QtGui
import shiboken
def getMayaWindow():
  # Get the maya main window as a QMainWindow instance
  ptr = mui.MQtUtil.mainWindow()
  return shiboken.wrapInstance(long(ptr), QtGui.QMainWindow)
print getMayaWindow()
Remember that PySide unlike PyQT returns the exact object, whereas PyQT returns the best match. That means the 2nd parameter has a strong importance.
Hope that helps,
