Announcements
problemas con el displaySmoothness
hola mi problema es que cuando intento cambiar la resolución del displaySmoothness no me funciona, aprieto 1 o 2 o 3 y no pasa nada, quizás bloque algo y me gustaría saber como desbloquearlo
RFlannery1
Lo siento. No escribo muy bien en español. Pero puede poner el siguiente texto en Google Translate.  https://translate.google.com/
The first thing I would do is to check what your hotkeys are set to for 1, 2, and 3.  What version of Maya do you have?  In Maya 2016, when you open the "Hotkey Editor" there is a picture of a keyboard.  If you hover the mouse over a key, you will see what function is assigned to it.
Is something assigned to 1?
  • No - You need to reassign the hotkey to the correct functionality.
  • Yes - If the wrong thing is assigned to the hotkey, you need to reassign the hotkey to the correct functionality.  If the correct thing is assigned to the hotkey and it still doesn't work, you may need to reset your preferences.
