Problem with GetAttr
anmiroshnikov
anmiroshnikov
While doing
select -r polySurface11.f [57];
getAttr polySurface11Shape.uvPivot;
// Result: 0.225335 0.293394 //
Everything is correct, but when done
float $ pos [] = 'getAttr polySurface11Shape.uvPivot';
it turns out
// Error: float $ pos [] = 'getAttr polySurface11Shape.uvPivot'; //
// Error: Line 2.16: Syntax error //
What am I doing wrong?
hamsterHamster
Spaces matter, whereas single quotes don't count. Use apostrophes (Shift+Tilde key) instead.
Also, use code block in your posts for your code (</> button), as who knows what every browser might do with your charset, which is especially damaging when Python code posted.
Here:
select -r polySurface11.f[57];
float $pos[] = `getAttr polySurface11Shape.uvPivot`;
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
anmiroshnikov
Thank you very much!!!
