polyExtrudeFacet provides naming (name flag) but the resulting polyExtrudeFace node has no name attribute
daniel_vanwesten
daniel_vanwesten
Hey there,
I tried to extrude a polyPlane via pymel:
pm.polyExtrudeFacet('pPlane', tk=0.3, name='myExtrude')
 The extrude works, but the name of the extrude node is polyExtrudeFace1. Shouldn't the Extrude node then be called "myExtrude"?
Cheers,
Daniel
Win 11, Maya 2024.1
FirespriteNate
you would assume so, but clearly not... 😕
Quite a lot of those types of commands all share several common flags like name, so it wouldn't surprise me if the engineers made some of them from a standard template, then just forgot to hook up all the common flags. The fact that the official polyExtrudeFacet command doc (which I assume is auto-generated from the source code) contains amazing pearls of wisdom like this:
would suggest that could be the case 😂
I assume you probably know how to work around this already, and are just highlighting the bug, but just on the off-chance:
pm.rename(pm.polyExtrudeFacet('pPlane', tk=0.3)[0], 'myExtrude')
