Announcements
Playblast mel script - help on file path please
magillaGuerilla
magillaGuerilla
This is the mel
string $blastPath = "R:/Maya/RED_111_VFX/Blocking/RED_111_160_VFX/";
string $path = `file -q -sn`;
string $basename = basename($path, ".mb");
playblast -format qt -filename ($blastPath + $basename + ".mov") -forceOverwrite -sequenceTime 0 -clearCache 1 -viewer 1 -showOrnaments 1 -fp 4 -percent 100 -compression "Photo - JPEG" -quality 100 -widthHeight 2048 1080;
I would like to update the text in green derived from the basename/file name.
Using
string $blastPath = "R:/Maya/RED_111_VFX/Blocking/" + $basename + "_VFX/";
returns this
// Result: R:/Maya/RED_111_VFX/Blocking/RED_111_160_BLK_001_VFX/
How can I concatenate to remove the green text (BLK and version number)?
any help much appreciated,
Cam
Kahylan
Hi!
given that this part of your string will always be in the same position in your filename (after the second to last "_" and the last "_"), you should be able to do it like this:
string $tkn[];
tokenize $basename "_" $tkn;
int $tks = `size($tkn)`;
string $reduceName = $tkn[0];
for ($i= 1; $i < ($tks-2); ++$i){
    $reduceName = $reduceName + "_" + $tkn[$i];
string $blastPath = "R:/Maya/RED_111_VFX/Blocking/" + $reduceName + "_VFX/";
I hope it helps!
magillaGuerilla
Awesome, thank you Kahylan
