Announcements
Placing objects together
Hi everyone,
i'm doing a project where i have to build a chessboard and chess pieces and then place each piece accurately on the board using Mel. So i'm wondering if there is a way i can set chess piece 1 to chessboard square 1 and so on in a for loop? I'd appreciate the help.
thanks.
Good Evening,
I while ago I used Mel but I switched over to python. I have created a code snippet for you which I guess can easily converted into Mel:
Edit: Here is the Mel code:
$width = 10;
$height = 10;
$size = 1;
$offset = 0.5;
for ($z = 0; $z < $height; $z++)
    for ($x = 0; $x < $width; $x++)
       spaceLocator -p (($x*$size)+$offset) 0 (($z*$size)+$offset);
import maya.cmds as cmds
width = 10
height = 10
size = 1
offset = 0.5
for z in range(height):
    for x in range(width):
        cmds.spaceLocator(position = ((x*size)+offset, 0, (z*size)+offset))
I think in Mel you need to adjust the for loops into
for ($z = 0; $z < height; $z++) {
spaceLocator();
 Width defines the items along the z-axis and height along the x-axis. Size defines the space between each "figure" and the offset pushes them into the middle.
So this would be the output:
So you just need to create 2 for loops for those 2 "teams" and it should be done 🙂 And if you want to access those objects later I would name them like the field name for e.g figure_2_3 where 2 is the row and 3 column so you can later compose a string "figure_"+$row+"_"+$column for accessing this figure. Good luck
Life
Circlelizer circle tool for Maya.
