Announcements
Pillow / PIP not working in maya
Craig_Lamorte
Message 1 of 24
Craig_Lamorte
I have done a pip install pillow already.  PIL resides in my python site-packages.  I can even run it just fine inside my text editor.  However when I add my code into a tool that is launched in maya 2017, i get an error "No Module named PIL"
I am doing -
from PIL import Image
Why does it not work inside of maya??
Craig
Replies (23)
Message 2 of 24
cheng_xi_li
Autodesk Support
Autodesk Support
Maya uses a custom build python(VS2012). I've written a blog for how to build pillow for Maya 2017. Please check it out.
Yours,
Li
Message 3 of 24
Craig_Lamorte
Is there any way to download the rebuilt pillow? without having to go through that process?  I do not have access to VS2012 so I can not do that process.
Message 4 of 24
cheng_xi_li
Autodesk Support
Autodesk Support
I do have my built for Maya 2017 stored on my personal google drive, here is link:
https://drive.google.com/drive/folders/0B5n3XnEYY_bVN1d5QWFiSUhGMG8?usp=sharing
Extract pillow.zip into Maya2017/Python and copy openjp2 into pil directory. For Maya 2018, you'll need to build with VS2015.
BTW: You can use VS2012/VS2015 Community version to build them.Microsoft provides them for free.
Yours,
Li
Message 5 of 24
Craig_Lamorte
Thank you so much!!! it works!!
Message 6 of 24
Thank you so much!
Message 7 of 24
328665042
Hello, Li Chengxi:
I've read your blog. I want to try to build the one for maya2018 and 3dmax 2018 by myself, but I fail to build at first step.
I first install vs2015 and Windows SDK 8.1 as you said, and I run VS2015 x64 Native Tools Command Prompt(VS2015 X64 本机工具命令提示符 ) as Administrator.
And I stuck into the setting enviroment variables step.
my Maya2018 installation path is C:\Program Files\Autodesk\Maya2018,
and my 3dmax2018 path is C:\Program Files\Autodesk\3Ds Max 2018
I write the following code in command prompt :
Path=%path%;"C:\Program Files\Autodesk\Maya2018\bin"
Python="C:\Program Files\Autodesk\Maya2018\bin"
The second line get a error:
Python: can't open file '=C:\Program Files\Autodesk\Maya2018\bin': [Errno 22] Invalid argument
I don't know how to fix it, can you help me?
Here is the screenshot of the error.
Thank you very much.
Yixiong Xu
2019.05.30
Message 8 of 24
cheng_xi_li
Autodesk Support
Autodesk Support
I think you should remove the quotes for the python settings. I remembered I had the same issue when I wrote this blog.
Yours,
Li
Message 9 of 24
328665042
Hi Li Chengxi,
Thank you for your quick reply.
I try your tip but it seems not work on my machine.
I remove it from both lines and I still get an error.
Here is my code:
Path=%path%;C:\Program Files\Autodesk\Maya2018\bin
Python=C:\Program Files\Autodesk\Maya2018\bin
Here is the error screenshot.
I'm a rookie in building python packages and I don't know how to do it.
Can you help me?
Yixiong Xu
2019.05.30
Message 10 of 24
cheng_xi_li
Autodesk Support
Autodesk Support
Setting environment variables should be using set command,
e.g.
set Path=%path%;Maya2017/bin
set Python=Maya2017/bin
Please use / instead of \ on windows platform.
Yours,
Li
Message 11 of 24
328665042
Hi, Li:
Thank you very much. It works without any error!!!
I'm going to the next difficult steps
Yixiong Xu
2019.05.30
Message 12 of 24
Craig_Lamorte
Going to be upgrading tools to maya 2020, and of course PIL still doesn't work.  And using PIL built in VS2012 also causes maya to crash.  I am guessing that for maya 2020 we need PIL built in a different version of visual studio?
Message 13 of 24
Are you referring to the tools in the google drive? If I were to use the google drive files with Maya 2020 wold Pillow work?
Message 14 of 24
cheng_xi_li
Autodesk Support
Autodesk Support
Yes, for Maya 2020 you'll need VS2017. It should be always the same as the requirement of the C++ developer environment.
Yours,
Li
Message 15 of 24
Craig_Lamorte
Ok thanks.  I don't suppose there is already a Pillow package out there rebuilt with VS2017 that i can download?  The instructions you wrote up for maya 2017/2018 and rebuilding it in VS2012 were a bit hard for me to follow.
Message 16 of 24
cheng_xi_li
Autodesk Support
Autodesk Support
Hi Craig,
No, there isn't. I could try to build it next week.
Yours,
Li
Message 17 of 24
cheng_xi_li
Autodesk Support
Autodesk Support
So, I've built one today.
There are some small issues. I am not sure why Pillow reported that it has tiff and openjpeg2 feature enabled after building but missing when I was running selfTest.
However, it seems that TIFF still works, so it shouldn't be a big problem.
Here is the link: https://drive.google.com/open?id=1aGCgPrAymmMuOxhYCCj75E34vLIYfNAS
Yours,
Li
Message 18 of 24
Craig_Lamorte
Thank you so much!!
Message 19 of 24
328665042
I recently restart building the Pillow Package for Maya2018 with VS2015.
In my opinion, I successfully build the Mandatory libraries(Zlib and JPEGsr9b) for Pillow 5.1.
As your suggest, I modify the setup.py file of Pillow with the correct library path.
But the build failed at the last step, the Pillow building always failed.
I don't know how to fix the problem, can you give me some suggestion?
BTW, I don't know how to build the Pillow with DEBUG mode on, can you show me some code for enabling DEBUG building?
Thank you very much!
Looking forward to your reply.
Yixiong Xu
2020.06.28
Message 20 of 24
328665042
After some tests, I successfully compile the Pillow 5.1 package(Minimum require) with VS2015.
I made a mistake when I compile the jpeg9b/9c lib.
For building the jpeg9b/9c, you need to NEW... a configuration for x64 platform, the original solution platform is Win32 which is not suitable for the Pillow build.
Building the Pillow package is really difficult for a newbie like me.
Anyway, thank you very much for your tutorial!
Yixiong Xu
2020.06.28
