Announcements
Object Parenting Problem
danispag
danispag
I have a list of Groups with a curve as a child object. I want to parent the group to the cild (curve) of the previous group. Images attached as an example. How do I do it wit python?
Thanks in advance 🙂
jarombrand
There are several ways you could do it, but here is one way with PyMel:
import pymel.core as pm
sel = pm.selected()
for x, s in enumerate(sel):
    if x:
        pm.parent(s, sel[x-1].getChildren())
Simply selected the groups in the order you want them parented and run this code. Let me know if you have questions about it
danielblaze
I'm getting this error:
# Error: line 1: MayaAttributeError: file /Applications/Autodesk/maya2017/Maya.app/Contents/Frameworks/Python.framework/Versions/Current/lib/python2.7/site-packages/pymel/core/general.py line 2200: Maya Attribute does not exist (or is not unique):: u"[nt.Transform(u'nurbsCircle2')]" #
jarombrand
Because Maya is dependent on node names, if there are duplicate node names in the scene it can screw things up. I would suggest properly naming your nodes before using this script.
