not all verts in selection appear in list when I do ls -sl
johnkeates2865
johnkeates2865
When I use ls -sl in MEL with a vertex selection, not all the verts are listed.
Do this:
>Create a SoccerBall poly shape and smooth it once.
>Select one of the verts which has six edges coming off it.
>Grow the selection ("shift" + ">").
>type the ls -sl MEL command.
When I do this, 12 verts are listed when there should be 13. Why?
Also, a lot of the selected verts are listed together (eg. "pSolid1.vtx[112:114]"). Why is this? I got around this by tokenizing but it is annoying.
Is there a better way to get a list of the selected verts?
mspeer
Hi!
Here they are listed all.
"[112:114]" does not mean 112 + 114, instead it means from 112 up to 114, so this selection includes 3 vertices.
johnkeates2865
Ah! so I need to make my script take that into account. Shouldn't be too hard. Is there an example of this code somewhere?
mspeer
Hi!
Try the following, that should return what you want:
ls -sl -fl;
or
print (`ls -sl -fl`);
johnkeates2865
Thanks! the -fl tag works like a charm.
