No echo from double3 attributes in the script editor
yoloff
yoloff
I've come across something weird that I can't fix myself (didn't find a setting, nor anything on the internet, nor anything on the ad forums).
I get no echo whatsoever from double3 type attributes from shading nodes. Other nodes and/or other attribute types return proper echo.
* With and without echo all commands. (attribute changes return a 'result' echo even with echo all = off).
* all 'suppress' options are off
* output is set to both (MEL + Python)
For example, a polySphere node will return echo on any attr change. Transform changes also return echo.
My problem is with shading nodes. For example - a simple lambert. If I change the diffuse amount (a single float value) - there's echo. If I change the diffuse color (a double3 value) or the opacity color etc - there's no echo.
This is Maya 2018.3 on Win 10.
Is there a setting that I'm missing? Maybe I've changed something without realizing?
Thanks in advance,
Alex
yoloff
Update - deleting the maya prefs does not help.
Alex
