Hi!
Normally this forum is meant to ask specific questions and not to get other people to do your homework.
But I get it, college can be tuff, so I'll help you out this time. Also because I was bored today tbh.
I haven't used py-charm in a while, so you'll have to figure out how to get the directorys right yourself. But basically this is the code that you want in your stacker Module:
import maya.cmds as mc
def stack_objs(o1 = '', o2 = '', o3 = ''):
stacks objects on top of each other. Takes three arguments (string), o1, o2, o3.
Names of the objects to be stacked
#check if correct arguments given
va = verify_args(o1,o2,o3)
if va == None:
mc.warning("one or more of the given arguments are not transforms")
return None
#stacking o2 on o1
tc = get_center_point(obj = o1, cl = -2)
bc = get_center_point(obj = o2, cl = 1)
create_stack(o2, bc = bc, tc = tc)
#stacking o3 on o2
tc = get_center_point(obj = o2, cl = -2)
bc = get_center_point(obj = o3, cl = 1)
create_stack(o3, bc = bc, tc = tc)
return True
def create_stack(obj = '', bc = [], tc = []):
stacks top objects on top of each other. Takes three arguments
obj (string) for name of the object to be stacked,
bc (list) for the bottom center point of the object (needs to contain three numeric values),
tc (list) for the top center point of the object to be stacked on (needs to contain three numeric values),
#moving object to origin
mc.move((-1)*bc[0],(-1)*bc[1],(-1)*bc[2],obj,r = True, ws = True)
#moving object to tc
mc.move(tc[0],tc[1],tc[2],obj,r = True, ws = True)
def get_center_point(obj = None, cl =1):
Gets bounding box information of given object (obj), returing top or bottom center point,
accornding to centerlevel (cl) bottom = 1, top = (-2)
#getting bounding box information
cp = mc.xform(obj, q= True, bb = True, ws = True)
#calculation mid x and mid z
cx = cp[0] + ((((cp[3]-cp[0])**2)**0.5)/2)
cz = cp[2] + ((((cp[5]-cp[2])**2)**0.5)/2)
return (cx,cp[cl],cz)
def verify_args(o1= '', o2 ='',o3= ''):
Verifies if given arguments contain information and are transforms
check = None
#run checks on all givem arguments
for arg in [o1,o2,o3]:
if arg != '':
if mc.objExists(arg)==True:
if mc.objectType(arg, isType = 'transform'):
check = True
else:
mc.warning('{0} is not a transform Node'.format(arg))
check = None
break
else:
mc.warning('{0} does not exist'.format(arg))
check = None
break
else:
mc.warning("empty argument given")
check = None
break
return check
I should mention that I didn't follow the instructions as religiously as your instructor seems to want you to in two instances.
1) The "get_center_point "function. Your instructor specified that he wants two flags, one for top, one for bottom. But that didn't really make sense in the logic for me, since those flags would be mutally exclusive because the return value needs to be a tuple with three values for the rest of the script to work. So I decided to have one flag instead with two different values. One for top and one for bottom.
2) The "verify_args" function. Your instructor advised you to only check if all the given arguments have a value. Which would look like this:
if '' in [o1,o2,o3]:
return None
return True
But this doesn't check if the objects given exist or if they are transforms, which is vital for the rest of the code to work, so I added an objExists and an isType check into it as well. And I gave each a specific warning if they are False.
Also, sice I was bored I decided to modify the script so it doesn't only take three objects and so it takes the selected objects as arguments if no object names are specified.
def stack_objs(*args):
#storing given arguments in objects
objects = []
for a in args:
objects.append(a)
#switch to selection if not enough arguments given
if len(objects) < 2:
objects = mc.ls(selection = True, et = "transform") or []
mc.warning('must specify or select atleats 2 objects')
return None
va = verify_args(*objects)
if va == None:
return None
for a in range(0, len(objects)-1):
#stacking objects
tc = get_center_point(obj = objects[a], cl = -2)
bc = get_center_point(obj = objects[a+1], cl = 1)
create_stack(objects[a+1], bc = bc, tc = tc)
return True
def verify_args(*args):
check = None
for arg in args:
if arg != '':
check = True
else:
check = None
break
else:
check = None
break
else:
check = None
break
return check
However, now that you can see how the code looks like. I would hope that you take your time to really read it trough and try to understand it. Otherwise you'll just end up stuck on next exercise... Also understanding how to code simple scripts like this can really make your day to day work with Maya easier.
Feel free to ask questions if you don't understand something.
I hope this helps!
