Announcements
MTransformationMatrix and Joint Orientation Python
flexmaster
flexmaster
Hey,
I'm trying to reconstruct a MTransformationMatrix from maya's MFnIkJoint in maya 2015. According to the docs the construction works as such:
The transformation matrix for a joint node is below.
  • matrix = [S] * [RO] * [R] * [JO] * [IS] * [T]
(where '*' denotes matrix multiplication).
These matrices are defined as follows:
  • [S] : scale
  • [RO] : rotateOrient (attribute name is rotateAxis)
  • [R] : rotate
  • [JO] : jointOrient
  • [IS] : parentScaleInverse
  • [T] : translate
So I've followed that and written the code below. The problem is that the constructed matrix I created does not seem to respect joint orientation.
If I get the MTransformationMatrix directly from the MFnIkJoint function it somehow seems to store the joint orientation. Does anyone know where the MTransformationMatrix is storing joint orientation? It seems to be a mystery to me as it isn't in MTransformationMatrix::rotationOrientation or MTransformationMatrix::rotation.
import time
from maya import cmds
from maya import OpenMaya, OpenMayaAnim
# Make a joint
jnt = cmds.joint(orientation=[0, 45, 0])
jnt2 = cmds.joint(p=[2, 0, -2])
# get a dagPath
mSel = OpenMaya.MSelectionList()
mSel.add(jnt)
dagPath = OpenMaya.MDagPath()
mSel.getDagPath(0, dagPath)
# Put it in MFnIkJoint function set
startJointFn = OpenMayaAnim.MFnIkJoint(dagPath)
initMatrix = startJointFn.transformation()
# Make a scale pointer
util = OpenMaya.MScriptUtil()
util.createFromList([1.0, 1.0, 1.0], 3)
scalePtr = util.asDoublePtr()
# Get scale
startJointFn.getScale(scalePtr)
S_MTMatrix = OpenMaya.MTransformationMatrix()
S_MTMatrix.setScale(scalePtr, OpenMaya.MSpace.kTransform)
S = S_MTMatrix.asMatrix()
# Get rotate orientation
RO_Quat = OpenMaya.MQuaternion()
startJointFn.getScaleOrientation(RO_Quat)
RO_MTMatrix = OpenMaya.MTransformationMatrix()
RO_MTMatrix.rotateBy(RO_Quat, OpenMaya.MSpace.kTransform)
RO = RO_MTMatrix.asMatrix()
# Get Rotation
R_Quat = OpenMaya.MQuaternion()
startJointFn.getRotation(R_Quat)
R_MTMatrix = OpenMaya.MTransformationMatrix()
R_MTMatrix.rotateBy(R_Quat, OpenMaya.MSpace.kTransform)
R = R_MTMatrix.asMatrix()
# Get joint orientation
JO_Quat = OpenMaya.MQuaternion()
startJointFn.getOrientation(JO_Quat)
JO_MTMatrix = OpenMaya.MTransformationMatrix()
JO_MTMatrix.rotateBy(JO_Quat, OpenMaya.MSpace.kTransform)
JO = JO_MTMatrix.asMatrix()
# Get inverse scale of parent.
parentMObj = startJointFn.parent(0)
if not parentMObj.apiTypeStr() == "kWorld":
    parentFn = OpenMaya.MFnTransform(parentMObj)
    parentFn.getScale(scalePtr)
IS_MTMatrix = OpenMaya.MTransformationMatrix()
IS_MTMatrix.setScale(scalePtr, OpenMaya.MSpace.kTransform)
IS = IS_MTMatrix.asMatrixInverse()
# Get Translation
T_Vector = startJointFn.getTranslation(OpenMaya.MSpace.kTransform)
T_MTMatrix = OpenMaya.MTransformationMatrix()
T_MTMatrix.setTranslation(T_Vector, OpenMaya.MSpace.kTransform)
T = T_MTMatrix.asMatrix()
# Multiply like the docs say.
matrix = S * RO * R * JO * IS * T
# Put it into MTransformationMatrix
TMatrix = OpenMaya.MTransformationMatrix(matrix)
# If the two MTransformationMatrices are equal.
if TMatrix.isEquivalent(initMatrix):
    # Set joint to calculated matrix
    startJointFn.set(TMatrix)
    cmds.refresh()
    # Wait 1 second and set it back to the inital transformation matrix from the joint function
    # This is just to see the difference between the two transformation matrices.
    time.sleep(1)
    startJointFn.set(initMatrix)
Thanks for any help!
You should not need to be doing this calculation
Instead you can just do
ikJoint.setScale   -- To set the [s] paramater
ikJoint.setScaleOrientation -- to set the RO parameter
ikJoint.setRotation  -- to set the R parameter
ikJoint.setOrientation -- to set the JO parameter
etc directly
That calculation you see is just done for the final rendering position of the joint
flexmaster
That makes sense. The question is what is set in the MTransformationMatrix that you get from the MFnIkJoint function set that stores the joint orientation? If I grab that set and use the set function in MFnIkJoint it retains the joint orientation. Where is joint orientation stored in the MFnTransformationMatrix?
What I was trying to say -- is that you shouldn't need to do that full calcuation your self, as you can do:
MFnIkJoint joint;
MTransformation transMatrix = joint.transformation();
From the TransformationMatrix -- You cannot get back the JointOrient    --- If you really need that ugly stuff -- you can directly ask MFnIkJoint.
TransformationMatrix -- however gives you the more important thing -- the total rotation:
The Total Rotation =  [RO] * [R] * [JO]    =  transMatrix.getRotationQuaternion()
flexmaster
Agreed. I shouldn't have to calculate it and I use the transformation in my code I supplied to show the differences between the two transformation matrices even though they say they are equivalent.
What's really odd though is that the MTransformation transMatrix = joint.transformation() part you're talking about some how retains the joint orientation in the MFnTransformationMatrix. That's shown when I grab the transformation matrix and then set it back onto the joint. Is this some weird under the hood maya thing that occurs that I can't actually reproduce because the api doesn't give you a function to add joint orientation?
There is probably a way to reconstruct them from the various member functions:
MTransformationMatrix -->
[Sp]x[S]x[Sh]x[Sp]x[St]x[Rp]x[Ro]x[R]x[Rp]x[Rt]x[T]
Looks like [Rp] x [Rt]  is related to the Joint Orient
