MPxNode compute array attribute independently
icapathos
icapathos
Hi, there
I am trying to create DG node to multiply matrix as array.
So, I add inputMatrix array, single multMatrix, and outputMatrix array attributes.
At that point, I want to compute array independently to increase efficiency.
So far, in "compute" all indices of outputMatrix have to be calculated.
How can I get a right way?
Your phrasing is a bit confusing. So you have a single matrix input, and another array matrix input, and you want the output to be each matrix in that a array multiplied by the  single matrix input?
This sort of dependency would done using the setDependentsDirty method on MPxNode, instead of using attributeAffects. The documentation explains it better than I can here.
icapathos
Sorry for confusing you, 😅
I meant that exactly what you said.
"setDependentsDirty" works as I want. Thank you for helping me.
