MPxGPUDeformer input mesh normals
Oleksandr_hrazhdan
Message 1 of 8
Oleksandr_hrazhdan
Hi. Is there a way to get an MAutoCLMem buffer with the input mesh normals, or should I compute them on my own in a separate kernel? Obviously there is no member function such as  MPxGPUDeformer::sNormalsName()
Replies (7)
Message 2 of 8
schwarm5
Also interested in this. In particular, seems that my mesh is going from soft edges to hard edges when I add my custom deformer, and would like to know if there's a way to pass through normals in MPxGPUDeformer. I see this method on `MGPUDeformerRegistrationInfo`, but it doesnt seem to solve my normal issue:
    virtual const MObject passThroughInputMeshAttribute();
Message 3 of 8
dongapkopal
Community Visitor
Community Visitor
I had this same issue recently. A mesh I was trying to export from Blender wouldn't load in any other program when I exported as an FBX. I was able to track down the faulty piece of geometry by deleting different pieces of the mesh and reexporting it until it didn't error out. I was able to fix the issue by separating off the faulty mesh into a separate object in blender then rejoining it to the main mesh. I don't know why that worked but I figured I would share https://100001.onl/ .
Message 4 of 8
schwarm5
@dongapkopal thanks but that's... not the same issue at hand here. We're talking about writing GPU deformers as part of custom plugins.
Message 5 of 8
Oleksandr_hrazhdan
at the moment I'm computing my per-point normals in a separate kernel. I use input points and also additional buffer with point neighbors. I'm not sure how much my result is different from what I can get from MFnMesh::getVertexNormals().
Message 6 of 8
schwarm5
How are you setting the recomputed normals back to the mesh after the separate kernel? Are you reading them back to the CPU first? That's what I'd like to avoid, but I don't see anyway to specify a deformer output buffer as a normal buffer.
Message 7 of 8
Oleksandr_hrazhdan
I use my computed normals for the mesh deformation. I don't need to pull them back to the host side. But if you need something back on the host side, you would use clEnqueueReadBuffer.
Message 8 of 8
schwarm5
I see. The opposite, actually- I want to keep the normals on the device. I don't need normals for mesh deformation, but I do want to specify the normals of the mesh *after* deformation, for shading purposes. I can't see any way to do that without reading them back to the host first, since there's no deformer output buffer for normals, as far as I can tell.
