Melscript Attr toggle help
Message 1 of 12
Hello! Im a bit new to melscript. I'm trying to create a script that will toggle the IK/FK attribute on a controller. I have it working before the "else" command but I cant seem to figure out how to get it to toggle 1 to zero in the second half.
select -r samus_RIG:C_IkSpinehipCtrl ;
if ( "samus_RIG:C_IkSpinehipCtrl.toFkSpine" == 0 );
setAttr "samus_RIG:C_IkSpinehipCtrl.toFkSpine" 1;
else
setAttr "samus_RIG:C_IkSpinehipCtrl.toFkSpine" 0;
select -cl ;
Accepted solutions (3)
Replies (11)
Message 2 of 12
lee.dunham
You'll want to look at the usage of ! in mel scripts.
setAttr "pCube1.visibility" (!`getAttr "pCube1.visibility"`);
Message 3 of 12
mcw0
If it's a true toggle you want, you only need the following...
1 - `getAttr samus_RIG:C_IkSpinehipCtrl.toFkSpine`;
Message 4 of 12
lee.dunham
Possible to clarify what you mean by a "true toggle"?
Message 5 of 12
mspeer
Hi!
@Anonymous in case you are confused by these 2 complete different examples, that's because you can set boolean values by numbers (0 or 1) or by using a state (false or true).
So all of this is valid (example for cube visibility):
setAttr pCube1.visibility 0;
setAttr pCube1.visibility 1;
setAttr pCube1.visibility false;
setAttr pCube1.visibility true;
The example from @lee.dunham works by negating the true or false state (NOT ...).
Try both:
print (! true);
print (! false);
The example from @mcw0 works by using a simple mathematical calculation (1 - ...).
Try both:
print (1 - 1);
print (1 - 0);
Message 6 of 12
lee.dunham
Worth pointing out that using as the not operator returns an integer (0/1), it can be used for most numerical attributes (int, float etc).
setAttr "samus_RIG:C_IkSpinehipCtrl.toFkSpine" (!`getAttr "samus_RIG:C_IkSpinehipCtrl.toFkSpine"`);
Due to its behaviour, its usually easier to read from context that it will be 0/1, on/off, true/false.
Message 7 of 12
mcw0
Lee,
I didn't see your response when I typed mine.  I only saw the post.  And in the original post, it was doing a setAttr of a value.  By "true toggle", I meant like a switch.  If it's 1, then flip it to 0.  And vice versa.  The conditional does that but with more lines of code.
I was unfamiliar with your usage of "!" so I've learned something new.  Thank you.
Message 8 of 12
hannah.novotny
Community Visitor
Community Visitor
Thank you guys so much! I'm sorry for the delayed response, I'm mostly on my work computer during the week, but I'll try to test these out soon!
Message 9 of 12
Dautryl
Hi!
First of all, sorry for the digging and thank you for that solution, I have been using it for a while now.
I am trying to transition from MEL to Python, I can't find a way to make that one work... Anyone knows how to do it?
My progression so far:
import maya.cmds as cmds
attrList = [
    "myObject.holdOut",
    "myOtherObject.holdOut"
for i in attrList:
    cmds.setAttr(attrList, cmds.getAttr(not attrList))
Which result in `error line 9: No object matches name: False`
So it really is getting the boolean toggle mixed with cmds syntax that puts me int.
Message 10 of 12
lee.dunham
for attr in attrList:
    cmds.setAttr(attr, not cmds.getAttr(attr))
You needed to use the iterated attr and invert the getAttr result 😉
Message 11 of 12
Dautryl
Awesome! Thanks!!! 😊
Message 12 of 12
triffski
Lovely stuff! 🙂
