Announcements
MEL Statements - HowTo execute more than 1 cmd under single IF
The-Digital-Shaman
The-Digital-Shaman
Hi there,
I have a question regarding basics of how statements' syntax works in MEL.
I have a working script which cycles through Move, Rotate and Scale tools.
I would like to upgrade the code by adding more commands to be executed under each IF statement.
Working Code:
string $currentTool = `currentCtx`;
if ($currentTool == "moveSuperContext")
setToolTo $gScale;
else if ($currentTool == "scaleSuperContext")
setToolTo $gRotate;
else
setToolTo $gMove; tumbleCtx -e -autoSetPivot true tumbleContext; manipMoveContext -e -mode 2 Move; manipRotateContext -e -mode 2 Rotate; manipScaleContext -e -mode 2 Scale;
What I tried to do, but doesn't work:
setToolTo $gScale; manipScaleContext -e -mode 2 Scale;
setToolTo $gRotate; manipRotateContext -e -mode 2 Rotate;
else
Thanks for advising what would be a good way around it.
Kahylan
I'm acutally quite surprised the top script works, as MEL synthax usually needs curly brackets {} to indicate the start and end of condition statements. This is how you would write your second script:
if ($currentTool == "moveSuperContext"){
setToolTo $gScale;
else if ($currentTool == "scaleSuperContext"){
setToolTo $gRotate;
else{
I hope it helps!
stephenkmann
You only need to scope with Curly Braces if you need more than one line of code.
so  the following works just fine:
    setToolTo $gScale;
else
   print ("this is fine\n");
but  for cleanliness, and more human readable I would indent the curly braces : ( even though mel doesn't respect white space)
    setToolTo $gScale;
    setToolTo $gRotate;
else
The-Digital-Shaman
Thanks guys!
Curly brackets then.
Btw, there is a bit of inconsistency in Maya and mode 2 for Rotate is Gimbal, not World Axis, like it is for Move and Scale. Mode 1 is World Axis for Rotate. ^^
