MEL script disappears after execute
patrick8CTF6
patrick8CTF6
Super NOOB question, I'm sure.
How to stop Maya from erasing the MEL script I'm working on when executing?
I can just keep copying and pasting from Notepad, but is there a setting to stop Maya from clearing the slate every time I run the script?
brentmc
Yes, this is a weird historic quirk of Maya. The trick is to either:
1) save the script to a file (which prevents Maya from deleting the script after running)
2) select the script before running. e.g. Ctrl-A, Ctrl-Return
Note: in the case where Maya deletes the script you can use undo (Ctrl-Z) to get it back.
Brent McPherson
Principle Engineer
patrick8CTF6
Awesome. Thanks @brentmc !
doom7787
I found a better solution , just in the end of your code add an error comand , somthing like " parent execute cancle" (MEL), maya builded in a way it wont remove your code if its cant complete it , by making that little error it will block your maya from clear your code or move you to somewhere like after Ctrl +Z , just make sure its the end of the code so it wont stop it in the middle
