Mel how to select same faces from current array, but on another object?
malcolm_341
malcolm_341
I've often run into this problem where I've got an array of face stored in a variable, but I want to substitute a new object name. I've seen this accomplished online, but I don't understand the code because it's written in short hand. Could someone help me figure this out.
//Store faces from first object
string $components[] = `ls -sl -fl`;
//Get name of second object manually select here this is just an example
string $obj[] = `ls -sl`;
//Loop through array swap names
string $newComponentSel[] = {};
for ($item in $components)
	string $comp = `match "\\..+" $item`;
	$newComponentSel[size($newComponentSel)] = ($obj[0] + $comp);
select $newComponentSel;
 This code works, but I don't understand the second line $newComponenSel[size($newComponentSel)] could someone write that out for me in long hand?
stuzzz
Hello Malcolm,
The line above is in a forLoop as you can see so anytime the loop iterate, the variable $newComponentSel which is an array has a new value.
It looks like a trick to append a new value ($obj[0]+$comp) at the end of the $newComponentSel array.
malcolm_341
What do the square brackets do, I haven't worked with those before?
stuzzz
The brackets means "the value at this nth index of this variable".
let's say you have this array:
string $myVar[]= {"banana", "toto", "titi"};
print $myVar[0]; // will return the first value which is "banana"
print $myVar[1]; // will return the next value which is "toto"
print $myVar[2]; // will return the last value which is "titi"
print $myVar[size($myVar)-1]; // will return the last value, same as above
malcolm_341
Oh interesting, thanks for that clear explanation.
