[MEL] how to get rendering image file name?
I want to get rendering image filename at current frame.
I can use "renderSettings -gin" just after maya startup.
string $ign[] = `renderSettings -ign`;
print("ign = " + $ign[0] + "\n");
string $gin[] = `renderSettings -gin $ign[0]`;
print("gin = " + $gin[0] + "\n");
<output>ign = %s.%e
<output>gin = untitled.iff
But after set "Frame/Animation.ext" to "name.#.ext" on Render Settings window, code above make maya hang up.
Do I misunderstand how to use this command? or any other way?
// Get the name of the first and last image for the current layer
string $fl[] = `renderSettings -firstImageName -lastImageName`;
print ("First image is "+$fl[0]+"\n");
// This is the empty string if the scene is not set for animation
if ($fl[1] == "") {
	print "Not rendering animation\n";
} else {
	print ("Last image is "+$fl[1]+"\n");
