[Mel] How can I freeze transformation without reset the rotate axis?
I want to keep the custom axis and the all values are 0.
The Bake Pivot restore the values base on custom axis.
But the three value will change when I rotate(just select one axis) it by custom axis.
I also found the internal. It have some scripts. it can achieve my aims but the function will create node and parent the mesh. I don't want to the node.
The purpose is only a value will change when I just rotate a axis by custom axis.
Please help, thanks.
rajasekaransurjen
not work
select object->group->set the pivot on group
The reault : still change 3 axis when I just rotate 1 axis by custom axis
I found the vedio fix the pivot but it need to create one more mesh to reset it.
I don't want to create one more mesh
absoluteKelvin
try this
channelBoxCommand -freezeTranslate;
channelBoxCommand -freezeScale;
https://www.artstation.com/kelvintam
