(MEL)Find the Correct Offset amount for polyExtrudeFacet?
absoluteKelvin
absoluteKelvin
Im currently trying find a way to obtain the correct amount of Offset value for poly Extrude base on percentage. If I wanted the polyExtrudeFacet to always extrude at 80% offset. How would I achieve that? Since setting it at 0.2 offset varies for each mesh depending on the size of the object. I having difficulty determining the correlation of the bounding box size to the offset value.
https://www.artstation.com/kelvintam
mcw0
What does 80% mean?  80% of what?
absoluteKelvin
imagine 100% is the extrude towards the center where it collapse into itself. I actually meant 20% when I said 80%, sorry.
Anyhow I think I came up with a method, not the most accurate but it kinda gets the work done.
global proc float findOffsetAmt()
    string $faces[]= `ls -sl -fl`;
    string $initBorderVtx[] = `polyListComponentConversion -fromFace -toVertex -border $faces`;
    string $flattenVtxList[] = `ls -fl $initBorderVtx`;
    vector $cPiv = `manipMoveContext -q  -position "Move"`;
    vector $pntPos[];
    vector $result[];
    float $sortedList[];
    float $distTmp[];
    int $counter = 0;
    for ($vtx in $flattenVtxList){
        $pntPos[$counter] = `pointPosition $vtx`;
        $distTmp[$counter] = `mag($pntPos[$counter] - $cPiv)`;
        $counter++;
    $sortedList = `sort($distTmp)`; //sort the list from smallest to largest
    //print $sortedList;
    float $smlDist = $sortedList[0];
    float $offsetAmt = $smlDist * 0.2;
    return $offsetAmt;
    //print $smlDist;
What I did was compare the distance between the closest border vertex to the component pivot. Then use that as a guide for 100% extrude offset, and Multiply by 0.2 to get the offset amount.
I would be happy to hear if there's a more elegant and accurate method.
mcw0
Just curious how different your result is compared to just scaling the geo by 1.2.  On a very organic shape,  I would venture it would be quite different.
absoluteKelvin
probably would be different. This a partial code for this tool im writing that require auto PolyExtrude offset
mcw0
That's very cool.  Have you thought of subdividing your original face selection and randomizing the faces along the edge to get an organic shape?  But very cool.  I hope you don't mind my stealing this approach in the future. 🙂
absoluteKelvin
Thanks. I plan to improve the Surrounding part more irregular. I don't mind you borrowing from this idea😉.
