(MEL)delete unused History and shape nodes of selected objects.
absoluteKelvin
absoluteKelvin
I know there is a command MLdeleteUnused that deletes unused nodes. But its destructive and delete all unused nodes even textures as well. What I need specifically is shapes nodes and construction history that gets left behind even after delete history.
https://www.artstation.com/kelvintam
mcw0
Yes, those pesky extra shape nodes.  You can get to those by using listRelatives a couple of times.
delete (stringArrayRemove(`listRelatives -shapes -ni`, `listRelatives -shapes`))
As for construction history nodes that are left hanging around, you can try "optimize scene size".
absoluteKelvin
thanks mcw0. elegant solution. unfortunately optimize scene size couldn't get rid of some of the lingering history.
I went with a less elegant solution by running DeleteHistory first> then run this
  string $mesh[] = `ls -sl -o`;
  string $mainShape[] = `listHistory -leaf true $mesh[0]`;
  string $allShapes[] = `listRelatives -s $mesh[0]`;
  string $emptyShapes[] = stringArrayRemove($mainShape, $allShapes);
  string $extrudes[] = `listConnections -type "polyExtrudeFace" $mainShape[0]`;
  string $cirulars[] = `listConnections -type "polyCircularize" $mainShape[0]`;
  string $chamfers[] = `listConnections -type "polyChamfer" $mainShape[0]`;
      catchQuiet(`delete $extrudes`);
      catchQuiet(`delete $cirulars`);
      catchQuiet(`delete $emptyShapes`);
      catchQuiet(`delete $chamfers`);
mcw0
It's true that optimize scene size doesn't catch everything.  But luckily in your case, you know the node types you are looking for.  I was thinking of a scene where you didn't know anything.  And you wanted to clean up all "loose ends".  There really is no elegant way that I know of other than going through each node type and checking for connections, as you've done.
absoluteKelvin
I will keep digging away at it until i find a better solution. but for now I will use this for a script im writing right now.
absoluteKelvin
after some extensive digging. I think i found a more elegant solution.  got the idea from http://discourse.techart.online/t/get-all-construction-history-nodes-in-a-file/3465/2
global proc delSelEmptyGeoNodes()
	delete (stringArrayRemove(`listRelatives -shapes -ni`, `listRelatives   -shapes`));
	catchQuiet (delete (`listConnections -type "polyBase" $mainShape[0]`));
 in my case using type "polyBase" is good enough.  There is also "polyModifier", both gave me the same results. I haven't test it extensively so im unsure what the differences are.
