Measure angle tool
Measure angle tool
Measure angle tool
Since there's no angle tool in Maya I've kind of built one myself using the MathNode that you can find on Autodesk Exchange.
There are two things I'd like some help with:
1. How do I make the distance arrows point directly at the locators?
2. How do I add a degree symbol (°) after the values in the corners of the triangle?
Here are the formulas inputted in the MathNodes if you want to build the tool yourself.
calcA: acos(((c*c)+(a*a)-(b*b))/(2*c*a))*(180/pi)
calcB: acos(((a*a)+(b*b)-(c*c))/(2*a*b))*(180/pi)
calcC: acos(((b*b)+(c*c)-(a*a))/(2*b*c))*(180/pi)
Since I know nothing about scripting and expressions I've made all this using nodes, so I'd like the answers to node based.
I've used this script for creating the annotations:
// campbell strong 5/05/03
// allows numeric display of attributes via numeric display on a single particle obj
// select attribute in outliner, call script.
global proc CSannoPart ()
$object = `ls -ap -sl`;
if (`size($object)`){
	string $obj;
	for ($obj in $object){
		if (`gmatch $obj "*.*" `){
			// and a test whether that attrib is numeric?
			$part = `particle -p 0 0 0`;
			addAttr -ln annoNumber -at double $part[1] ;
			setAttr ($part[1]+".particleRenderType") 2;
			addAttr -is true -dt "string" -ln "attributeName" $part[1];
			if (catch (`connectAttr $obj ($part[1]+".annoNumber")`)){
				print "you have a non-numeric, or a compound attribute selected for annotation (thus the clash error above) - they will be skipped with no ill effect.";
				print "n";
				delete $part;
				continue;
			setAttr  -type "string" ($part[1]+".attributeName") "annoNumber";
			$owner = `listHistory $obj`;
			$trans = `listRelatives -f -p $owner[0]`;
			if (`nodeType $owner[0]` == "transform"){
				$trans[0] = $owner[0];
			if (size($trans[0])){
				if (`confirmDialog -title "annotatn arrow?" -message ("use an annotation arrow on ntransform closest to: n"+$obj+"?")
    					-button "Yes" -button "No" -defaultButton "Yes" -cancelButton "No" -dismissString "No"`
    		 			==  "Yes") {
    		 				// annotateNode.mel:
						$pos = `xform -q -ws -t $trans[0]`;
						$locator = `spaceLocator -n "annotationLocator#" `;
						xform -ws -t $pos[0] $pos[1] $pos[2];
						parent $locator $trans[0];
						select -r $locator;
						$annotationNode = `annotate -tx "" -p ($pos[0]+3) ($pos[1]+1) $pos[2]`;
						string $transform[] = `listRelatives -parent $annotationNode`;
						parent $transform[0] $locator;
						parent $part[0] $transform[0];
						setAttr ($part[0]+".t") 0 0 0;
						setAttr ($part[0]+".overrideEnabled") 1;
						setAttr ($part[0]+".overrideDisplayType") 2;
						select -r $annotationNode;
    		 	rename $part[0] annoPart;
		} else {
			print "need to select attributes in the outLiner for 'annotation display'.";
			print "n";
} else {
	print "n";
anatoliiCD3WB
Observer
Observer
Nice, but why autodesk just do not make it by themselves? They are so lazy?
jmreinhart
I think that the angleDimensionShape is meant to display the angle, and I have a vague memory of it doing that a few years ago, so there might be a bug with that node since it does not display anything in the viewport.
