Mayapy Interpreter Error
bayareadeck
bayareadeck
Working in windows 10 command line mayapy interpreter.
Why am I getting this error ?
set PYTHONPATH=%PYTHONPATH%;C:\mayapybook\pylib
SyntaxError: invalid syntax
e_honda
mayapy.exe is a Python interpreter.
The set command you wrote is a windows command.
https://docs.microsoft.com/en-us/windows-server/administration/windows-commands/set_1
*to be more precise, %ENVIRONMENTVARIABLE% is used in bat and cmd files.
  • If you call a variable value from a batch file, enclose the value with percent signs (%). For example, if your batch program creates an environment variable named BAUD, you can use the string associated with BAUD as a replaceable parameter by typing %baud% at the command prompt.
if you wanna change environment variable, you should do it before you start mayapy.exe.
rem this line changes environment variables
rem this line starts mayapy.exe interpreter
mayapy.exe
Or, alternatively, you should change it in a inside your Python interpreter.
import os
import sys
append_path = r'C:\mayapybook\pylib'
# change environment variable
os.environ['PYTHONPATH'] = '%s;%s' % (os.environ['PYTHONPATH'], append_path)
# change sys.path
sys.path.append(append_path)
Hope it helps
