Maya vs Mata LT vs Maya Indie check from c++
Sebastian_Wiendl
Message 1 of 1
Sebastian_Wiendl
Hi all,
First of all, is Maya Indie the same as Maya LT? Are there any other versions?
My main question is: Is it possible to check which version someone is using from c++.
I see that there is a mel about -ltVersion command (https://help.autodesk.com/cloudhelp/2017/ENU/Maya-Tech-Docs/Commands/about.html#flagltVersion).
I guess, I could call that command from MGlobal via the executeCommand api, but I would prefer c++.
Also, if there are any other versions than LT (like Indie, if that one is different from LT), how would I test for them?
Thanks so much
Cheers,
Sebastian
Replies (0)
