Maya Python issue
Maya Python issue
Maya Python issue
i have a class A that creates new renderLayer in maya
when user clicks create button (of class A) , a command is calling a function of the class , say funcA
cmds.button( label="Passes",command=("self.funcA()"))
now, this class A (resides in a file) in a package and is called from another class B
but with the click following error occurs
NameError: file <maya console> line 1: name 'self' is not defined #
What am i missing
there is another command which works
cmds.button( label=" Close ", command=("cmds.deleteUI(\"" + self.win + "\", window=True)") )
this too has a 'self' being called. But this works
crydrk
I don't know if this actually solves the problem, but I usually pass commands a different way.
For example:
import maya.cmds as cmds
class PrintWindow():
def __init__(self):
win = cmds.window()
cmds.columnLayout()
cmds.button(label = 'Print', command = self.printer)
cmds.checkBox(label = 'Checkbox', changeCommand = self.printer)
cmds.showWindow(win)
def printer(self, junk):
print 'We have reached the class method "printer"'
print 'This is what gets passed in when called:', junk
PrintWindow()
Perhaps it could be having a problem finding the method because of calling the function in quotes? Not sure but just a thought. The reason why I add a 'junk' is because when the method is called, a value is passed in. I added the checkbox to show that for things like checkboxes and dropdowns the value is passed but in the case of a button it's always false. I'm not sure if that is also the case when passing a string of the function so just in case I added that tangent of an explanation 🙂
